1.01:- Fixed: radio button wouldn't dissapear when in Stopped state in File Info large size.1.02:- Added Tabs width options for Vertical Tabs. 1.03:- Fixed Visual Display menus. Right-click always opens "Mode/Visualization/Skins" now.1.04:- Adjusted "Tabs width - medium" size so that it is balanced between original size and large size.- Made "Tabs width" to reflect better if they are available or not. Shortly: they are very dark if Vertical Tabs is not enabled.1.1:- Added Equalizer as an option to Simple mode. You can chose between File Info and Equalizer in Design Options. Note: they are disabled if you have disabled Complex/Simple switch.- Changed Radio capture icon. Hopefuly better.- Adjusted: File Info can't be changed if it's disabled.- Adjusted: Preset button from EQ can be right-clicked to acces DSP Manager quickly.1.11:- Fixed: radio button wouldn't dissapear when in Stopped state in File Info large size. Again.1.12:- !! Embedded SegoeUI fonts in the skin so that everyone will get the exactly same look. Before, having your SegoeUI font modified would make the skin different. That's the reason why the skin is over 1mb size now.- Fixed: Shading option 4 for Tray-Control. Should look better.- Adjusted other minor things.1.13:- Added an option to disable or enable Title indenting. Not everyone likes indenting.- Fixed other minor things.1.14:- Fixed the problems caused by the update to AIMP 3.50 RC2 build 1270.1.15:- Fixed another issue from Aimp3.50 RC2 update.1.2 (Final):- Nothing modified. Compiled with the final version of Skin Editor 3.50 so that I can sleep well without thinking of this as a Beta anymore.- This is pretty much the last update it will get unless I find critical issues.
You can enable Design options by pressing the Gear icon (top left corner of main window). There you have most of options.
Можно ли добавить обложку дистрибутив плеера?
Сомневаюсь, что будут добавлять. А надо ли вообще?
