AIMP for Android v3.10 Beta Testing has been stared
Today we have started public beta-testing of AIMP v3.10 for Android OS!
  • General: action list for gestures has been extended with few new commands
  • General: appearance of settings dialog has been improved
  • General: night mode - an ability to specify night time manually
  • General: night mode - support for system settings for night mode
  • General: support for external file providers
  • General: support for otg-drives
  • Bookmarks: added search support
  • Bookmarks: an ability to create auto-bookmarks for files
  • Bookmarks: an ability to edit bookmark's time
  • Bookmarks: new auto-catch behavior for files and playlists
  • Bookmarks: now all bookmarks grouped by a track
  • Player: album art file size limitation has been removed
  • Playlist: an ability to copy / move selected files to specified folder
  • Playlist: an ability to specify default sorting and grouping templates
  • Playlist: an ability to suspend user queue
  • Playlist: support for the PLS file format
More details you can find in our blog.
Please, report all issues which were found through feedback form and / or by our forum.
Please, refer to the beta-testing rules topic before send bug reports, try as much as possible to describe in detail the situation in which the error occurred, or provide the steps to reproduce. Do not forget to mention the full version of the program.
Follow as
Beta-testing of AIMP for Android v3.10 is delayed
Start of public beta-testing of AIMP for Android v3.10 is delayed. Now, we planning to start testing at beginning of August.
Follow us
AIMP v4.70 has been released
Whats new in AIMP v4.70?
  • Common: the Folder Browser dialog now saves its size between work sessions
  • Common: the WM_APPCOMMAND message is now supported by secondary windows of the app
  • Player: an ability to set hotkeys for speed / tempo control
  • Playlist: support for incremental search
  • Playlist: the "collapse unused groups automatically" option has been added
  • Playlist: the tracklist content settings now invokes from the "Save As" dialog
  • Playlist: an ability to select tracks via translucent selection rectangle
  • Music library: the "Catalog" field has been added
  • Sound Engine: radio capture - the "skip the track if file with same name is already exists" option has been added
  • Sound Engine: replay gain - the default value is now used as a basic value for the "on-fly" analysis
  • Sound Engine: upper limit of speed control has been increased to 3x
  • Tag editor: an ability to remove tags from WAV-files in batch mode
  • Tag editor: autofill tags - support for %albumartist% and %totaltracks% macros
  • Tag editor: compatibility with Windows Explorer has been improved
  • Tags: now the app ignores spaces around multiple values separator
  • Plugins: AlbumArt Visualization - now you can change rendering mode clicking on visualization display
  • Plugins: BASS_MIDI - added an ability to use few sound fonts at same time
  • Plugins: information bar - the "show before playback finish" option has been added
  • Plugins: information bar - transparency options now affects to the Card view too
  • Plugins: information bar - updated UI of settings dialog
  • Plugins: MyClouds - support for "Shared With Me" category for OneDrive and Google.Drive services
  • Plugins: MyClouds - support for changes in API of Cloud@Mail.ru service
  • Plugins: Update Checker - an ability to select update channel (Alpha / Beta / Release)
  • [/ul]
    New version is already available in our download center.
    Follow as
    AIMP v4.70 Beta
    Today we have started public beta-testing of new version of AIMP for Windows - v4.70.
    In this version, we focused on improve existing features, increase stability and usability of the app. Full change log you will find here. here.
    Forum section of AIMP for Windows
    Note that this version is for tests only, it may contains many bugs!
    Follow as
    AIMP for Android v3.00 released!
    Today we have released of AIMP v3.00 for Android OS!
    • General: Android v4.4 is now minimal supported operation system version
    • General: native supports of x86-64
    • General: import / export of user's data and settings
    • General: an ability to control playback via gestures in area of album art
    • General: supports for custom CarPC based on Android OS
    • General: supports for the smb:// protocol - support for shared Windows folders
    • General: performance has been improved
    • UI: new app design
    • UI: an ability to customize accent intensity
    • UI: an ability to hide status bar
    • UI: an ability to switch manually between tablet and phone layouts
    • UI: style of settings dialog is now depended from used skin
    • UI: support for night mode
    • UI: support for non-square album arts
    • UI: the Pandemic skin has been added as additional built-in skin
    • UI: waveform-navigator support (skin must support this feature too)
    • UI: welcome screen has been added
    • Bookmarks: now you can delete bookmarks for non-existent files via the swipe-to-refresh gesture
    • Sound engine: cross-mixing feature now take tracks duration into account and automatically reduces mixing time if necessary
    • File Adding Dialog: a "home screen" has been added that contains a list of all available volumes and sd-cards
    • File Adding Dialog: an ability to pin folders at home screen
    • File Adding Dialog: an ability to sort content by name / last modified
    • File Adding Dialog: supports of the swipe-to-refresh gesture
    • Playlist: sorting and grouping templates a completely redesigned
    • Playlist: the %FileModifiedDateAndTime macro has been added
    • Playlist: the swipe-to-refresh gesture now works only if you drag the list at top edge
    • Sleep timer: the "at end of queue" event has been added
    • Sleep timer: shake device before the action now restarts the timer instead of cancel the action.
    • Skin Engine: potential abilities has been extended
    Follow as
